Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Can not save » » » » Post: Re: Can not save |
Print at Oct 3, 2026, 12:24:48 AM |
| Posted by hansmex at Jul 3, 2010, 11:16:52 AM |
Re: Can not save Bandit: If you use the online version, you will have to register first and login to your account before you can save your design. There is a clear message above the working area that says so. If you haven't created an account, or if you haven't logged in, you have a problem, because in both cases you will lose your work. If you always work with your laptop, you may consider using the installed version from the Download Section. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Oct 3, 2026, 12:24:48 AM |
