Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Stair builder » » » » Post: Re: Stair builder |
Print at Sep 24, 2026, 12:33:23 PM |
| Posted by dorin at Mar 11, 2025, 1:29:55 PM |
Re: Stair builder Errata: While only today I've have a feedback from a macOS user you need to install this or this updated version. I'm sorry for the inconvenience. It have to look something like this: ![]() ![]() ![]() ![]() ![]() @Keet & not only On the right last row I've insert information's related to the next level(if exist). At start, the plugin verify this and set the calculated thickness. Modifying the steps number, the next level indicator will warn you. When next level: 0 cm you have to be sure the last tread it is at the same elevation as upper room. Try with the test file I've provided. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Sep 24, 2026, 12:33:23 PM |
