Print at Sep 26, 2026, 5:44:00 PM
Posted by Keet at Mar 24, 2025, 5:00:27 PM
Re: I am having trouble doing roofing
Plugins are are stored in the home directory in a subdirectory named '.eteks' (that is on Linux, on other systems probably something similar and it's a hidden directory so check that these are visible).
Under that directory there is a subdirectory sweethome3d/plugins. Just backup the files in that directory. Actually, only the plugin manager plugin is necessary since with that plugin it is easy to install the other plugins.
With the boxes: if grouped they should all resize with the same percentage, not with a fixed number. Make sure you select the group and not the individual boxes.
If that doesn't work you can use the resize function. I think it's a feature of the advanced edit plugin.
And if THAT still doesn't work you can select all boxes and export/import them. Then the group is a single object that should resize as one.
