Print at Sep 27, 2026, 5:10:11 PM
Posted by Keet at Mar 24, 2025, 5:08:25 PM
Re: How to create workplaces for my kitchen
You will have to be a little more specific.
For simple tops you can resize a box. Use a stretched cylinder for a rounded border.
On my site under Kitchen2 there is a small library with replacement noses for kitchen tops that you can use. Or you can download the shapes library that has half cylinders and objects for the corners.
For random shapes the easiest way is to use a room. Draw and curve walls for the outside of the worktop you want. Double click inside to create a room. Select and export only the room, import it and adjust the height to what you want.
