Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Delete old textures » » » » Post: Re: Delete old textures |
Print at Oct 2, 2026, 3:16:43 AM |
| Posted by Keet at Mar 26, 2025, 11:01:40 AM |
Re: Delete old textures On Linux: In your user directory there is a hidden folder ".eteks" with a subfolder sweethome3d. Simply remove the old textures from the sweethome3d folder. The textures are image files but with names like "Texture-some-numbers.pref". Switch to an icon view to see them as images. Make sure to check "show hidden files" in your filemanager otherwise you will not see hidden files and folders (folders starting with "."). If you want to remove a complete texture library you can find them in the subfolder "textures". A texture library is a zip file with the extension ".sh3t". After restart the removed textures/libraries should no longer appear in the texture catalog list. On other systems it will probably be (almost) the same. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 2, 2026, 3:16:43 AM |
