Print at Sep 27, 2026, 7:03:17 AM
Posted by Keet at Mar 28, 2025, 11:57:01 AM
Re: How to use 3D models with several items?
Your model didn't include the mtl file but I think I found part of the problem even before you uploaded this model.
In the mtl file "newmtl" for the knob doesn't have a material name.
Change "newmtl " to "newmtl Knob".
Of course the same problem is in the obj file (g 152).
The usemtl line for the knob is "usemtl ". Change that to "usemtl Knob".
That still doesn't solve the problem. Blender can import the model without problem and an export from Blender can be imported in Sweet Home 3D.
But that's not what we want.
Export the knob from Sweet Home 3D. Change the scale of the texture to 256 because the 1024 resolution is rediculous for a small knob. You will not see the difference but it decreases the overal object size tremendously.
Import the knob and use that for the cabinet.
Now you can export the parts and import a complete cabinet.
Apparently you have to first export/import the AI model before you can use it as a part in Sweet Home 3D. So far I didn't find what the problem is in the obj file, aside from the missing material name.
Blender doesn't have a problem with it so it might be a problem in the obj importer of Sweet Home 3D.
