Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: I am having trouble doing roofing » » » » Post: Re: I am having trouble doing roofing |
Print at Sep 24, 2026, 3:36:53 AM |
| Posted by Keet at Mar 28, 2025, 7:10:45 PM |
Re: I am having trouble doing roofing It's very simple: Create 4 boxes, one 200 wide, one 30 wide, one 70 wide, and one 100 wide. Give all boxes a depth of 100 and give each box a different color. Place the 30, 70, and 100 wide boxes under the 200 wide box. Now group all 4 boxes. This should result in a 200x200 square of boxes. The group has a handle on one of the corners with which you can resize the group. While you do that you can see what happens in the 3D view. All boxes resize and the width of the top box and the combined three smaller boxes remains te same. You can also use the modify dialog on the group. If you change the width to 400 the width of the bottom three boxes will change to 60, 140, 200, and the top box will be 400 wide. Notice that objects grouped in an angle can sometimes give strange results when resizing. If possible first rotate the group to horizontal, resize, and rotate back. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 24, 2026, 3:36:53 AM |
