Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Render bug in windows » » » » Post: Re: Render bug in windows |
Print at Oct 4, 2026, 9:46:51 PM |
| Posted by db4tech at Jul 5, 2010, 3:26:42 AM |
Re: Render bug in windows Hi Zoli, It's probably a long shot but have you tried updating to the latest graphics driver, to see if it helps fix the preview display problems? (It won't help with the texture mapping, because that is how Sweet Home is set up) Nvidia In connection with your texture mapping issues. If you want all surfaces to display a correct facing texture, the only way is, to use a dedicated 3D modeling application and apply the texture/s to the surfaces using UV mapping, then export the model as an .obj file with .mtl (material library and images) which you can then import into Sweet Home for scene construction. If not already tried, I hope the driver idea helps fix the display glitches. PS: Make sure you close all open applications, before updating graphics drivers. db4tech |
Current timezone is GMT Oct 4, 2026, 9:46:51 PM |
