Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Wirings plugin » » » » Post: Re: Wirings plugin |
Print at Sep 23, 2026, 10:37:08 AM |
| Posted by Keet at Apr 13, 2025, 2:04:00 PM |
Re: Wirings plugin I never used the Wirings plugin so I can't help you with that but... I physically solved it, using a trick seen on the forum to solve other problems by positioning a solid inside the objects (in my case a sphere of minimum dimensions) Don't use a sphere for this. A Sphere is a huge object in terms of vertices and faces compared to for example a Box. If you hover over the object in the top-left catalog window you can see that the default Sphere is 50kB and a default Box 2kB. With 50+ spheres it's no surprise that things slow down a little.If you really need a sphere then use an Ico Sphere from my DodecagonShapes library. The smallest one is 6kB. Use a color, not a texture. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 23, 2026, 10:37:08 AM |
