Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Wirings plugin » » » » Post: Re: Wirings plugin |
Print at Sep 23, 2026, 10:37:00 AM |
| Posted by [email protected] at Apr 14, 2025, 5:47:24 PM |
Re: Wirings plugin hi,Keet I'm glad you've recovered well from your health problems. As usual you're rich in information. Thanks. I knew that the impact was due to the size of the objects (complexity of the construction plot), even if I noticed slowdowns even using objects that partially pierce the walls. On the other hand, realism is paid for in terms of processor calculations. The use of a sphere was only to test the wiring connections that otherwise did not work correctly. I will forward the question to daniels118 (maybe via email directly)....in the meantime I will continue to trace my systems with the old method which, moreover, having three-dimensional dimensions, signals installation problems (overlaps and impossibilities due to the thickness of the walls) which is very useful in the design phase |
Current timezone is GMT Sep 23, 2026, 10:37:00 AM |
