Print at Oct 2, 2026, 1:11:33 AM
Posted by iaw4 at Apr 15, 2025, 12:29:15 AM
Columns, Beams, and Roofs
I am trying to create a basic barn skeleton. Think carport that is a cube. No walls, just beams and pillars. I found the beam and the column, and they are good starts. The two items that give me trouble are:
[1] the columns need to go three feet into the ground. Alas, negative elevations are not allowed. (Maybe one can draw a floor level that is 3’ higher?)
[2] I want a roof on top. worse, I want it to be angled, so on one side of the roof, it is higher by 2 feet than it is on the other side. It’s really just a slab of steel, sitting on rear pillars that are 14’ high and front pillars that are 16’ high.
Has anyone solved a similar design problem? If so, could you please share a sample or advice?
