Print at Oct 2, 2026, 4:27:17 AM
Posted by iaw4 at Apr 17, 2025, 2:08:48 AM
Re: Columns, Beams, and Roofs
I apologize. I need more handholding. I have my real simple model, in csv form
Name Width Depth Height Visible
Metal beam 504 9 7.875 true
Porch column 13.125 13.125 204 true
I managed to install the roof manager, but after reboot, the plugin is always grayed out.
Similarly, I don't know how to set the elevation. Do I start with Plan->Add Level; and then call this level "-1", put it at -6', give it 6' high, and then view it? All good and easy, but I still need to be able to somehow indicate that I have a floor. at 6', and that I want my porch column to go down 6', and then punch out to the ceiling. (ideally, my floor would be semi-transparent, so that the underground part looks a little more grayed out than the above ground of the column.)
Pointers appreciated.
