Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Wirings plugin » » » » Post: Re: Wirings plugin |
Print at Aug 25, 2026, 1:15:57 AM |
| Posted by [email protected] at Apr 17, 2025, 6:12:12 PM |
Re: Wirings plugin Ciao daniele Per spiegarmi meglio qui ho postato un files con le prove con i miei oggetti . Ciascun livello riguarda tipologie di collegamento cosi' come indicate. Il primo livello (nascosto) contiene dei miei test sulle polilinee (alcune prodotte con Wirings altre direttamente con Sweethome) in cui ho sperimentato cosa provoca l'apposizione di nuovi punti nell'oggetto polilinea semplice. Il secondo (base) il muro (reso semitrasparente) ed i miei oggetti che lo forano parzialmente. Salutim Hi Daniel To explain myself better here I posted a file with the tests with my objects. Each level concerns types of connection as indicated. The first level (hidden) contains my tests on polylines (some produced with Wirings others directly with Sweethome) in which I experimented with what causes the addition of new points in the simple polyline object. The second (base) the wall (made semi-transparent) and the my objects that partially pierce it. Greetings https://www.mediafire.com/file/g0j3dzw9at8jo5p/Polyline_with_wirings.rar/file |
Current timezone is GMT Aug 25, 2026, 1:15:57 AM |
