Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Not a 3D problem, 2D massive slow-down on 'busy' project » » » » Post: Re: Not a 3D problem, 2D massive slow-down on 'busy' project |
Print at Sep 26, 2026, 6:13:39 AM |
| Posted by Keet at Apr 18, 2025, 7:19:21 PM |
Re: Not a 3D problem, 2D massive slow-down on 'busy' project The solution is to use 3D models instead of walls where possible. For roads there is a nice Furniture Library: https://sweethome3d.com/support/forum/viewthread_thread,11079#51676 Another trick is to use Rooms for roads/driveways. Enclose the area in walls and double click inside to create a room. Then remove the walls. A room is a much simpler object than a wall and you can still take advantage of curves like with walls. It's also easy to modify it by editing the room points. A room also has the advantage (for a road) that is has no height. You can create road pieces with walls or rooms and export these. Then import an re-use them like with the models from the library. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 26, 2026, 6:13:39 AM |
