Print at Aug 25, 2026, 1:15:59 AM
Posted by [email protected] at Apr 19, 2025, 3:17:15 PM
Re: Wirings plugin
Hi daniel
Thanks for providing me with the Wiring maxima design guidelines and the method to follow to trace the paths.
From what I understand, my objects INTENTIONALLY used to partially drill the walls cause the behavior.
The solution of building parallel walls could be good (apart from doubling the walls of an entire floor plan) could be valid if all the objects had the same depth otherwise you should provide accordingly.
Question is it possible to act having the walls on another level? Let me explain.....
On levels all with the same base
Level 1 the floor plan and the walls
Level 2 the solid objects (the plates with the sockets, the covers of the junction boxes, the fake light points on the ceiling or elsewhere) on which to trace
Level 3 my objects to partially drill
Would this allow you to trace correctly? If so, then it would be enough to choose the level to display or turn off on the walls of Level 1
Happy Easter
