Print at Oct 5, 2026, 8:53:44 AM
Posted by Keet at Apr 24, 2025, 7:02:46 PM
Re: Creating complex room with no flat walls as a road or path - 'create room' doesn't.
You can still use the method with curved walls and create a room between, then remove the walls. You will probably need multiple parts but that should be no problem.
Read this post from Dorin where it's explained with both text and images: https://sweethome3d.com/support/forum/viewthread_thread,12618#59201
Replace "river" with "road" and you get the idea smile
