Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Generate roof plugin » » » » Post: Re: Generate roof plugin |
Print at Sep 23, 2026, 7:06:22 PM |
| Posted by dorin at Apr 30, 2025, 8:58:52 PM |
Re: Generate roof plugin New version 4.7.1 (Francis) News: -improves the roof windows library (version 0.2) --correct the previous and add a new one which could be used for holes on the roof face --it could be used to do dormers more easy -adapt the plugin code to use it I'm not fully satisfied, so TODO: improving the holes in the roof to be more accurate in all situations Also on Source Forge Suggestion: remove the previously versions. @captaincook Thanks for the inspiration. @Keet 1. The mean of roof_window_deep I've explained at the last part of V.4.5 tutorial 2. If I wanted to create a roof window, how do I determine what the roof_window_deep value should be? Or is it always 11.0? It mean how much of the window height you decide should be inside the roof.3. I need you to help me to improve (to be functional) and simplify (reduce number of) roof windows. ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Sep 23, 2026, 7:06:22 PM |
