Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Generate an Object: a panel with a hole » » » » Post: Generate an Object: a panel with a hole |
Print at Sep 29, 2026, 10:07:19 AM |
| Posted by Keet at May 1, 2025, 8:47:19 PM |
Generate an Object: a panel with a hole Several times we have seen questions in this forum about how to create a hole in a object. In most cases for a kitchen counter where a hole is needed for a sink. Look no further because now you can generate a panel with a hole according to your own specifications using the Object Generator on dodecagon.nl. You fill in the dimensions you want and after clicking "Generate" you can download a zip with your panel-with-a-hole. You can even select if you want the material to be Color, Glass, or Mirror(Chrome). (Texture is not one of the options but the generated object is perfectly prepared to set a texture after import in Sweet Home 3D.) Disclaimer: This is a beta version and simply a proof-of-concept. The idea is that maybe some day the original C# code is converted to a plugin that can generate multiple basic furniture parts. You can find it under Projects on Dodecagon.nl. ![]() So far I can generate seven different objects for a wall system: supports, shelves, triangle shelves, toekicks, backsides, doors, and drawers. All with the selectable material types Color, Texture, Glass, or Mirror. And they can be smoothed, something Sweet Home 3D can't do. These objects have a small (or big) bevel that with smoothing creates a very natural looking rounding of the edges. Especially the handles for the doors and drawers look a lot better when smoothed. With these seven elements I can create thousands of different cabinets. And all I have to do is enter the dimension parameters to generate a part. The functions I set up are capable of extra options like setting an elevation for the drawer and door handles, a choice between one or two handles on a drawer (and turn them up or down). For the doors I can choose the hinges at the front or at the back. The front hinges are for doors that fall between the cabinet sides and the back hinges are for a door outside the cabinet. And of course the doors and drawers open in Sweet Home 3D. One parameter sets the hinge or rail number to generate for that object so a combination of generated objects can be exported/imported as a single object. The backside object can be with a color or texture and optionally with a mirror front. Next to these seven parts I already have functions to generate a beveled door border, a beveled window border, a beveled panel, and a panel-with-a-hole (surprisingly the simplest of all objects). For those who are interested a bit of history A while ago I needed to create the same furniture part but with different dimensions for my Shopping Mall project. The problem was that some parts had to remain the same. Simply resizing one object was no option. Now I'm a software developer and as such I am basically lazy . I don't like to create the same object in 10+ different dimensions, there's no fun in that. I like to create once and let the computer repeat it whenever and however I want.The problem definition was how to create a furniture part with different dimensions but with some other parts remaining as they are. Think about a door that you resize but with the handle remaining the same size. It took many hours, heavy analyzing of obj files, and many tries to see how I could replace the static vertice coordinates with variables that I can set with parameters, but I succeeded. Looking back it was not that difficult after I used Blender export instead of the Sweet Home 3D export as a template obj file. I found that it was important to meticulously prepare a template file with no double occurrences of a dimension to help recognize what is what in the resulting obj file. That was the key to succes: a well prepared obj template. It helped a lot that I discovered the need to merge vertices that were not correctly aligned in the Sweet Home 3D export. If you export two boxes aligned side-by-side the touching corners should share a single vertice point. Unfortunately this was not the case in a lot of situations with other parts. Thus the need to use Blender to merge those points. The extra advantage is one v line less for each merge. This makes the file much more 'readable' but of course it's a lot of work that fortunately only has to be do done once. Then trouble started: texturing. Texturing is described in the obj with the vt lines ("vertice texture"). And depending on the object there can be as many vt lines as v lines but the values are in no way as recognizable as the v lines. It took a lot of time for each template to figure out the conversion algorithms for each vt line so that a texture remains correct for each size of the generated object. That is the most difficult and time consuming part of preparing a template for generation. I still have a bug in the window border template where the conversion algorithm for one or more vt lines is incorrect. So far I haven't found it. Experimenting with different exports from Sweet Home 3D and Blender resulted in keeping the Blender export as a template for conversion. Two important reasons for this: First Blender doesn't create loads of vn lines that would also have to be converted. Second, instead of the vn lines Blender sets a single s line: 's off' flat, 's 1' smoothed and a different set of f lines. Yes, that means you can simply change flat to smoothed by setting 'off' to '1'! No need to create TWO templates, one for flat and one for smoothed, simply change between 'off' and '1'. Fortunately the f lines don't need a conversion, they remain the same for each size. That's how far I am today. This is all code in C# which must be converted to Java if and when I find the time for a plugin. Since C# and Java are 95% the same conversion should be simple. The plugin itself and user interfaces is probably more work. The proof-of-concept on the dodecagon site was too much trouble. Converting C# to PHP is no fun at all. I will not do that for the other objects. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 29, 2026, 10:07:19 AM |
