Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Import custom fonts, can it be done? Google AI says "no" » » » » Post: Re: Import custom fonts, can it be done? Google AI says "no" |
Print at Sep 23, 2026, 4:31:22 PM |
| Posted by Keet at May 8, 2025, 5:54:29 PM |
Re: Import custom fonts, can it be done? Google AI says "no" I assume you want to use a textbox for the text. Then place it on a object/box and export as a sign. As far as I know you can select every font that is correctly installed on your system. Find the right font and install it and it should show in the font selection pulldown on the modify textbox dialog. That said, the quality of such a text is average at best. I would create an image with the text in GIMP and set that image as the texture. Make sure the face (box top) you put it on has the same scale as the image. For example an image of 400x200 has a scale of 2:1 so make the surface size 400x200, or 300x150, or 100x50, etc. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 23, 2026, 4:31:22 PM |
