Print at Sep 23, 2026, 2:32:12 PM
Posted by Keet at May 9, 2025, 6:10:30 AM
Re: Import custom fonts, can it be done? Google AI says "no"
If you only need to see it in the 2D pane then the text function should work as you want.
Carefully check that you installed your fonts correctly. On Linux I also have to follow the correct procedure before I see new fonts in Sweet Home 3D. That Chrome shows the fonts doesn't say you installed them correct. I don't know anything about Windows so I can't help you there but I'm sure there are plenty of sites with help articles about how to do this.
