Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: How to curve Funiture? » » » » Post: Re: How to curve Funiture? |
Print at Sep 29, 2026, 6:31:44 PM |
| Posted by dorin at May 16, 2025, 5:52:30 PM |
Re: How to curve Funiture? Just like in real life, SH3D and even you can't bend a straight object (chair, table or box) without breaking it. Also, just like in real life, if you need it, you can create it (and SH3D can do that). You could do this with the help of room or wall. 1. From room: 1.1. Add a level and set the floor thickness at the height of needed object. ![]() 1.2. Draw bounding walls and curve the necessary. ![]() ![]() 1.2.1. Fill the space with a room OR 1.2.2. Use Autodimensioning plugin to generate the build surface. ![]() ![]() 1.3. Select the generated room and 3D view -> Export to OBJ format. ![]() 2. From wall: 2.1. Draw a wall, set the height, the thickness and the curve. 2.2. Select the wall and export it as object. 3. Furniture -> Import furniture... and import the exported object. ![]() ![]() For more precise and funny you could use Multiplier plugin. ![]() ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Sep 29, 2026, 6:31:44 PM |
