Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Plugins manager » » » » Post: Re: Plugins manager |
Print at Sep 23, 2026, 10:38:16 PM |
| Posted by Daniels118 at May 17, 2025, 9:37:57 AM |
Re: Plugins manager If the plugin manager tells you that there are plugins/updates available, it means that the program communicates without problems with my own website. When you click install/update, the plugin is downloaded directly from it's original source (with very few exceptions). Both Auto dimensioning and Multiplier plugins are downloaded from SourceForge, so the handshake problem should lie there. Try to download the plugin directly using this link, and check if you get the same alert from your browser: https://sourceforge.net/p/sweethome3d/plug-in...AutoDimensioning-1.6.sh3p If you get the error, that means that you have to install the CA certificate which has released the certificate for SourceForge; usually this is not required, most of the times it's because the whole system is outdated and needs an upgrade. If you get no error, then the problem is that the JRE you are using to run SH3D uses it's own truststore, and this is outdated. Since nobody else has faced this problem, it could be that you have installed SH3D from the system package manager; if this is the case, please uninstall SH3D, and then download and install the one from the official website. |
Current timezone is GMT Sep 23, 2026, 10:38:16 PM |
