Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Door with two panels » » » » Post: Re: Door with two panels |
Print at Sep 28, 2026, 7:48:01 PM |
| Posted by Keet at May 22, 2025, 10:10:44 PM |
Re: Door with two panels I started to compare both versions manually (currently I have not installed the compare extension in Visual Studio Code)... I forgot to give this tip: You are on Linux. It has this little program called "diff" that is probably installed by default. Check it out with "man diff" in a terminal window to see all the options.---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 28, 2026, 7:48:01 PM |
