Sweet Home 3D Forum » List all forums » » Forum: New versions » » » Thread: Furniture Library Editor released » » » » Post: Re: Furniture Library Editor released |
Print at Sep 23, 2026, 11:54:30 AM |
| Posted by selden at Jun 9, 2025, 6:29:18 PM |
Re: Furniture Library Editor released Problem: warning messages from Java jdk-24 I'm a irst time (attempted) user of the library creation tool under windows 10. I installed and configured Java jdk-24, which seems to work. 1. How can I display the current documentation for the furniture library creation tool? 2. invoking the command + java -jar ./FurnitureLibraryEditor-2.2.jar opens the editor window. However, when I tried to drag-and-drop of the directory folder containing the .obj and .mtl files into the main pane of that window, nothing happens but I get this error message in the cli (I'm using cygwin bash) command window: WARNING: A restricted method in java.lang.System has been called WARNING: java.lang.System::loadLibrary has been called by com.jogamp.common.jvm.JNILibLoaderBase in an unnamed module (file:/C:/User s/selden/Documents/sh3d_models/FurnitureLibraryEditor-2.2.jar) WARNING: Use --enable-native-access=ALL-UNNAMED to avoid a warning for callers in this module WARNING: Restricted methods will be blocked in a future release unless native access is enabled Hopefully this problem can be fixed in the next release of the Furniture Library Editor. In the meantime, I'll try what java suggests. ---------------------------------------- Selden |
Current timezone is GMT Sep 23, 2026, 11:54:30 AM |
