Print at Sep 23, 2026, 4:21:27 PM
Posted by Waldemar.Hersacher at Jun 19, 2025, 11:39:25 AM
Re: Keep folder structure intact
I'm not sure how that translates when you add it to a library, I'll have to investigate that.
The editor will create a subfolder and copy the obj-file in it. It copies the mtl-file and renames it to the same name as the obj-file. The obj-file is changed to reference to the the mtl-file. It copies the texture and renames it to have the name of the obj-file an underscore and its original name. The mtl-file is changed to reference to this texture.
If you add multiple objects you will get the same mtl-file and texture multiple times with different names in the subfolder of each obj.
In my case with three doors with a white panel and three doors with a wooden panel I have the following sizes:
sh3f: 101.543 Bytes -> 92.331 Bytes
sh3d: 303.417 Bytes -> 103.476 Bytes
If you are interested you can download the files.
WaHeModDoors.sh3f
WaHeModDoors_common.sh3f
Version_14_wood.sh3d
Version_14_wood_common.sh3d
MSI GP60, Linux Mint 21.3 Virginia base: Ubuntu 22.04 jammy, SH3D 7.5 with Photo-video rendering 2.8
