Print at Sep 24, 2026, 2:15:27 PM
Posted by robca at Jun 23, 2025, 12:19:52 AM
Weird texture problem (bug?)
I'm lost trying to understand what's happening with a tiled texture (I'm trying to replicate a Hardie panel siding)
The texture is simply a rectangle with border
I built a wall, applied that texture, then added a door. For some weird reason, the texture changes where the door ends
https://www.mediafire.com/view/z20x7s4nmwaxwu...025-06-22_154702.png/file
If I move the wall with the door back a bit (not the virtual camera, move the wall and door "up" in the screen), the texture renders correctly
https://www.mediafire.com/view/29zfg5l984edh3...025-06-22_154825.png/file
Photo rendering behaves the same
Here is the file used https://www.mediafire.com/file/mvaz634fl8m4brr/texture.sh3d/file
It looks as if a wall is more than 66' 11 1/4" from the origin, the problem happens. If the wall is at or below 66' 11 1/4", it doesn't happen (in metric, between 2040.2 cm and 2041.1)
Which is a very big home unless, like me, you position the house in the center of a decent size lot
