Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Launch multiple instances of SweetHome3D? » » » » Post: Re: Launch multiple instances of SweetHome3D? |
Print at Oct 2, 2026, 1:12:40 AM |
| Posted by Keet at Jul 5, 2025, 8:48:12 AM |
Re: Launch multiple instances of SweetHome3D? Be aware that with separate instances you won't see a newly imported furniture or texture library in one instance in the other instance until you restart it. With a single instance setup you would see an imported library immediately in all open projects. In your case I don't think that will be a problem but remember it when you have two instances running for normal editing and you import furniture or textures. Also understand that photo rendering will not be faster by doing it in two instances at the same time instead of one after the other. The only advantage is that you can start them both and let them run through the night. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 2, 2026, 1:12:40 AM |
