Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Feature Request: Set exact distance between walls using dimension lines » » » » Post: Re: Feature Request: Set exact distance between walls using dimension lines |
Print at Aug 25, 2026, 2:58:31 AM |
| Posted by GaudiGalopin3324 at Jul 7, 2025, 10:39:18 AM |
Re: Feature Request: Set exact distance between walls using dimension lines Hey bro. There is a very simple and reliable way to place objects with the right distance from the walls and from each other. These are the template boxes. For example, you need to put a sofa 100cm away from a wall and 50cm away from another wall. Turn on the magnet and stick a 100x100cm brown box template (No. 1) to the wall. On the other wall is a blue box 50x100 cm (No. 2). Stick the sofa to the blue box first. Now make another green box No. 3, stick it to box No. 1. SH3D has an important tool for aligning to the side of an object. It is available in the "Furniture" column. You saw the template with the mouse first, then grab the sofa with it, click "align to the left". That's it, the sofa will stand up exactly as it should. You can't put up walls with a magnet like that, but you can also use boxes instead of walls. I only do all the interiors with boxes, it's more convenient this way. ![]() |
Current timezone is GMT Aug 25, 2026, 2:58:31 AM |
