Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: a curved wall » » » » Post: Re: a curved wall |
Print at Sep 23, 2026, 1:17:00 PM |
| Posted by Keet at Jul 13, 2025, 11:48:25 AM |
Re: a curved wall And an even easier circle... Yes, another way to create a wall circle and with the advantage that the walls are connected Draw a line from left to right, than back to left - double-click to end and attach it The last segment will be highlighted - modify the arc to 180 degree Now you can see the first segment, modify that also to 180 degrees Ready When you curve a wall it actually creates a series of straight wall sections that are rotated around a curve. In some cases that has too little detail (or too much!) for what you want. To get around that there's another way: Instal the Generate Regular Room plugin. Set the number of sides to a number that fits the level of detail you want and generate the room (max sides is 300). Select the create wall tool and double click in the room. It will create a wall around the room. In the case of a 128 sided room the wall circle will have 128 sections to form the circle, with 12 sides, a circle with 12 wall sections: dodecagon ![]() ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 23, 2026, 1:17:00 PM |
