Print at Sep 27, 2026, 5:07:41 PM
Posted by Keet at Aug 15, 2025, 8:53:35 PM
Re: Wrong (Big) Text dimension in menu
If you have the version from the repository then download the latest version from the download page. You can leave the installed version as is.
Edit the launcher and replace the command line with "<path-to-unzipped-download>/SweetHome3D-Java3D-1_5_2-7.5" (the current version is 7.5). If you create a new launcher then use the SweetHome3DIcon.png in the unzipped folder as an icon.
First try a different desktop and see if the problem persists.
