Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Help with vaulted ceiling » » » » Post: Re: Help with vaulted ceiling |
Print at Oct 2, 2026, 4:32:26 AM |
| Posted by Keet at Sep 17, 2025, 9:40:42 AM |
Re: Help with vaulted ceiling On the lower level uncheck both "Display ceiling" and "Flat ceiling only". On the upper level uncheck "Display floor" and "Flat ceiling only". That should do it. If you have trouble with getting a nice alignment between walls: On the upper level do not join the sloped walls with the straight walls or do not use straight walls between the sloped walls. Make sure the sloped walls align with the outside of the lower walls. If you get an open space between the lower and upper level because there is no floor on the upper level: add the floor thickness as defined for the upper level to the height of the lower walls. This will extend the lower walls to the bottom of the sloped walls. An alternative: don't use the ceiling options at all, uncheck them for both levels. Then use the Roof Generator plugin to create a nice roof. This roof has its own (sloped) ceiling. Roof Generator plugin v5.0 ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 2, 2026, 4:32:26 AM |
