Print at Oct 2, 2026, 2:32:46 PM
Posted by Keet at Sep 21, 2025, 8:19:25 AM
Re: Help with vaulted ceiling
Extend the room for roof generation a little outside the outer walls before generating. It gives you a roof where you can attach raingutters.
It doesn't work for all houses but the generated roof is an object like all other furniture: you can resize it to get the same result.
Using the interior surface like you describe is great if you just want a ceiling. That comes in handy if you have a roof like I described that extends outside the exterior walls but you want a different ceiling fort the part inside the house and the part that extends outside the house. Just add this second roof at a little lower elevation for an interior ceiling. That hides the ceiling that extends outside the house so you can give different textures to the parts inside and outside the house.
