Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Unable to Start Sweet Home 3D After Installing Pan 3D View + Wiring 4.4 Beta 2 » » » » Post: Re: Unable to Start Sweet Home 3D After Installing Pan 3D View + Wiring 4.4 Beta 2 |
Print at Sep 23, 2026, 5:08:03 PM |
| Posted by Keet at Sep 28, 2025, 6:58:04 PM |
Re: Unable to Start Sweet Home 3D After Installing Pan 3D View + Wiring 4.4 Beta 2 I don't know anything about Windows but that you found two different directories with plugins seems wrong. It could happen that Pan3DView is installed in one and the Wirings in the other. Then the Wirings plugin will not find the Pan3DView plugin. Copy both plugins in only one of the directories. If that works OK, if not then move them both to the other directory. If that works you have found the directory that is the correct one for your current Sweet Home 3D. Now it should work. ETA: Once you can start Sweet Home 3D you can easily find the correct directory: Menu > Help > About. Click the button "Libraries". This will display a dialog with three lists. The bottom list shows the installed plugins. If you click one it should take you to the directory where it is installed. It is one of the two directories you found with plugins. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Sep 23, 2026, 5:08:03 PM |
