unable to calculate photo
This topic has been viewed 8981 times and has 3 replies
architetto20
Post by architetto20 »
Hi!
I'm having a problem with rendering. When I launch the "create 3D photo" function, a red X appears in the window shortly afterward, saying "unable to calculate photo." Help! Thanks... [:(]
Re: unable to calculate photo
Post by Keet »
Probably not enough system resources available.
See "How can I adjust the memory used by Sweet Home 3D" on the FAQ page to increase the amount of memory Sweet Home 3D is allowed to use.
MarioSambol
Country: Croatia
Post by MarioSambol »
What kind of computer hardware do you have?
Daniels118
Country: Italy
Post by Daniels118 »
Try to create a new project, insert just one model and try to render. If it shows the red X, then the problem is not the available memory. Then post the result here so it will be easier to assist you.
Users browsing this forum: No registered users and 0 guests
