Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Split Wall, how to separate the two ends » » » » Post: Split Wall, how to separate the two ends |
Print at Oct 2, 2026, 5:15:29 AM |
| Posted by KENTSOR at Oct 2, 2025, 3:33:25 PM |
Split Wall, how to separate the two ends I have used the split wall command and the wall is indeed in two parts but I cannot work out how to separate them. If I select the first part and go to Modify Walls and change the end point, the start point of the second part moves with it. Conversely if I change the start point of the second part, the end point of the first changes. Basically, the two parts are not separate. Of course I have also tried having one section selected and dragging the end of the section away from the other. I tried having one section selected and reversing wall direction, but that didn't seem to make a difference. I tried selecting both and and seeing if you needed to do split wall again, but the command isn't there anymore. What am I missing? |
Current timezone is GMT Oct 2, 2026, 5:15:29 AM |
