Print at Oct 2, 2026, 6:52:44 AM
Posted by Keet at Oct 2, 2025, 7:37:06 PM
Re: Split Wall, how to separate the two ends
Not sure what you are doing wrong: select the TWO non-connected walls you want to connect. A right click opens a context menu that should have the "Join walls" command.
Another way is what dorin described but again: first select TWO walls. Then use one of the two functions under the Plan menu: Join and Connect ('Connect walls' only if you have the Advanced Edit plugn installed).
The two functions (join and connect) under the Plan menu act a little different and depend on which walls is selected first to determine where the connection is made. The Join function from the context menu extends both walls and connects them where they intersect.
Are you using some ancient version of Sweet Home 3D where this function was not implemented yet? The latest version is 7.5 and with two walls selected the Join functions should be visible.
