Print at Oct 2, 2026, 1:50:09 AM
Posted by Keet at Oct 7, 2025, 10:15:09 AM
Re: Split Wall, how to separate the two ends
It sounds like the two wall segments are still joined at their endpoints. After using the Split Wall command, try selecting one segment, right-clicking the end, and choosing Disallow Join. Once the little join symbol disappears, you’ll be able to move or stretch that section independently. Repeat for the other end if needed—this should let you separate and adjust both parts freely.
"Disallow Join"? As far as I know there is no such command in Sweet Home 3D. When you split a wall the walls are joined at the splitpoint because that is how you are most likely to use it. If you want a segment to disconnect you select that segment and cut/paste it, simple as that.
A disconnect command on the splitpoint could be usefull since it will leave the other end connected (if it is). With cut/paste both ends are disconnected.
