Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Re: Create a solid Shape » » » » Post: Re: Create a solid Shape |
Print at Oct 1, 2026, 10:16:16 PM |
| Posted by Keet at Oct 20, 2025, 1:48:48 PM |
Re: Create a solid Shape What do you mean by 'solid'? An exported/imported room IS a solid object. I'm not sure what else you expect or what you need. ETA I looked at your file. You exported both walls and room. Select only the room and export that. After import you can adjust the height to a solid block with the height of the walls. That what you are looking for? ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 1, 2026, 10:16:16 PM |
