Print at Oct 2, 2026, 5:21:41 AM
Posted by stef.salmon at Oct 21, 2025, 2:09:24 PM
Re: Create a solid Shape
Sorry for going back and forth on this.
Below are two samples, the 1st is what I'm trying to do now and the 2nd was one I did where the walls are just either straight or slightly curved. The Create Wall tool works perfect for the 2nd option. I can use the same method for the 2nd one, but because there are all different shapes it takes so long to do.
The 2nd option works like you said by manually drawing the walls as rooms and then clicking in the area, which draws in the walls, however there are voids between the walls, which I suppose isn't a major issue, but they would look nicer filled, if that makes sense.
Example 1
https://www.dropbox.com/scl/fi/j4joyst5wgc76p...tvfliyfi0moiap00&dl=0
Example 2
https://www.dropbox.com/scl/fi/bfd9s2xvd2ee4i...lo9f4otc6cvhf9h1&dl=0
Thanks.
