Print at Oct 5, 2026, 11:28:16 AM
Posted by drmrbrewer at Jul 24, 2010, 10:53:05 AM
Default dimensions of imported furniture
Hi
Excellent program -- thank you.
When I import some of the furniture from the 3D models page, the default dimension assigned to the furniture is wrong -- the default size is tiny.
For example, the red "Kitchen cabinet" imports with a default height of onl 4cm!
Is there any way to make these default dimensions correct? It is possible to edit manually on import, but it's better if you at least start with what the model author had in mind for that object.
Thanks!
