Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: lost all my imported models after update » » » » Post: Re: lost all my imported models after update |
Print at Oct 21, 2026, 5:16:42 AM |
| Posted by Keet at Nov 2, 2025, 9:40:11 AM |
Re: lost all my imported models after update Somebody else has to help with where models are stored, I have no idea about locations on a Mac. Use one of the following methods when you have the location where the obj/mtl and zip files of the models are stored: 1. You can select multiple obj and zip model files and drag&drop them into your 2D pane. They will show the import dialog one after the other without having to select <Import> from the menu. That still requires four times the <Enter> key for each model to import. 2. Create a new furniture library with the Furniture Library Editor. Use the same method of dragging&dropping multiple selected models into the editor, they will all import without the need of four times <Enter>. A much faster method! You will have to edit the models that are doors, windows, or staircase to check the appropriate properties. Then import the library in Sweet Home 3D. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 21, 2026, 5:16:42 AM |
