Print at Oct 21, 2026, 3:20:58 AM
Posted by MarioSambol at Nov 5, 2025, 11:56:04 AM
Re: lost all my imported models after update
This is normal if you install a new version because it only contains the default library. Basically, you should always have your own library file, which you then import into the newly installed version. It is easy to make with the editor for library files.
