Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Light Problem » » » » Post: Re: Light Problem |
Print at Oct 21, 2026, 1:41:55 AM |
| Posted by Keet at Nov 15, 2025, 3:54:35 PM |
Re: Light Problem You can only see the light when you generate a photo, not in the 3D view. You can set the light power when you modify the light (Modify furniture): at the bottom right you will see a setting "Light power" with a default value of 50%. In most cases that is way too much, often 5-10% is more than enough. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 21, 2026, 1:41:55 AM |
