Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Ceiling » » » » Post: Re: Ceiling |
Print at Sep 29, 2026, 5:10:13 PM |
| Posted by hansmex at Jul 28, 2010, 4:45:28 PM |
Re: Ceiling Axelmars: If you need TWO ceilings, you can simply make TWO rooms inside that one large space: one with ceiling ON, one with ceiling OFF. Second way is, indeed, to insert a flat box. Advantage of this option is that a box is opaque from both sides; ceilings are opaque only when seen from below. With oblique you mean that the ceiling is not a perfect square? Use one or more triangles around a box to form any other four-sided shape. Rotate the triangle while importing to get the correct orientation. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Sep 29, 2026, 5:10:13 PM |
