Print at Sep 23, 2026, 11:50:52 PM
Posted by Keet at Dec 3, 2025, 8:24:27 AM
Re: Areal View Problem
Check the menu > Help > About. The dialog will show the Java version that is used. Compare them between the desktop and laptop. Your best bet is using the Java version provided with Sweet Home 3D, both for the 3D display and photo rendering. (Use the SweetHome3D_Java3D-1_5_2 script from the .tgz download for an example.)
ETA:
I tried Sweet Home 3D with the latest Java (1.8.0_471/jre8U471) and everything seems to work fine. I needed that to fix an issue with the pluginmanager that now works as it should. Also no problems with zooming in 3D view. You can try that too.
