Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: WishList: lock individual objects » » » » Post: WishList: lock individual objects |
Print at Oct 20, 2026, 9:38:51 PM |
| Posted by Keet at Dec 4, 2025, 2:51:17 PM |
WishList: lock individual objects We can lock the base plan which locks walls, rooms, doors, windows, and objects where we checked the property "Part of base plan". This prevents accidentally moving or changing the objects that are part of the base plan. Basically you can't do anything with these objects while the base plan is locked. I use this quite often to make the objects in a large group part of the base plan so I don't move them when organizing other furniture. I also often export/import floors and walls to use as replacement objects for said walls and/or floors. The only way to lock these is to make them part of the base plan, but... that locks everything in the base plan. And I only want to lock specific objects. The same when you group a set of objects that are spread over your whole project. Such a group is a pain to work around because it's always in the way of other furniture, even if you push it to the top of the furniture list. A perfect solution would be if the group could be locked. My wish: Have an option to lock a specific object or group without having to lock the complete base plan. Add a checkbox column in the furniture list named Locked to lock/unlock objects; same as the Visible column. Of course the objects should still have the option to be part of the base plan so they are locked when the base plan is locked. ---------------------------------------- Dodecagon.nl 1300+ 3D models, manuals, and projects |
Current timezone is GMT Oct 20, 2026, 9:38:51 PM |
