Print at Oct 2, 2026, 1:16:40 PM
Posted by db4tech at Aug 3, 2010, 7:45:11 PM
Re: Great Program... Many thanks! .....but there are a few questions..
Ah I can see what the problem is.
The lamps are exactly 10 cm wide in Sweet Home, so if you look at your plan view (baring in mind that the wall lights are tapered) you will probably find the bottom of the light is slightly in front of the base of the wall light.
if the wall prevents you moving your light then use the modify button instead, then you can enter a value to move the light further into the wall lamp and slightly inside the wall itself.
db4tech
Or do you mean the bedside tables? If so don't worry, the next release will fix this but for now you may have to use Advanced render to prevent your furniture items losing their colour.
