Print at Oct 2, 2026, 6:58:37 PM
Posted by db4tech at Aug 3, 2010, 9:16:32 PM
Re: Great Program... Many thanks! .....but there are a few questions..
If your textures show fine with Advanced render, then it is the already mentioned problem with the currently available version of Uber.
The render process is being worked on, so don't worry! smile For now just use the Advanced render if you encounter texture colour loss problems.
PS: Yes you can have both render files installed without any problems.
To make your vases transparent, edit your mtl file and enter (below the Ns value of the texture you would like to be transparent)
d 0.2 (or any number less than 1)
I have carried out many, many tests and at the moment Sweet Home only sees either transparent or opaque.
The Kd value controls how light or dark the transparency will be. 1 is normal, less than 1 the object becomes darker.
Extra information for you: Frosted glass, Alpha blending or multiple layered textures aren't an option at the moment.
BTW there is an edit button (if you see my post above) I'm not sure if it only becomes available after x amount of posts or when the user status changes. This is one to ask Emmanuel! smile
db4tech
