Print at Oct 20, 2026, 6:33:08 AM
Posted by Keet at Jan 17, 2026, 6:09:45 PM
Re: Moulding Boolean Convert plugin (MBC)
Does the plugin use the obj definition for each object? (i.e. the definition in the .obj file.)
If so then try another sphere, one from my shapes library or one generated in Blender. Also try an Ico sphere from my shapes library, an ico sphere has a different kind of definition.
If that works then export the initial sphere you used and import it again. I suspect that it's definition is straight from Blender.
As it is, great results so far!
