Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Moulding Boolean Convert plugin (MBC) » » » » Post: Re: Moulding Boolean Convert plugin (MBC) |
Print at Oct 20, 2026, 12:39:09 AM |
| Posted by dorin at Jan 18, 2026, 8:25:50 AM |
Re: Moulding Boolean Convert plugin (MBC) The updated alpha2 version. The previous link is updated too. I made a few changes and now it seems to be working. pict14 ![]() pict15 ![]() pict16 ![]() pict17 ![]() pict18 ![]() @Keet Thanks, you've encouraged me! The plugin (like SH3D) does not work directly with obj files. -Exports the furniture as obj+mtl+texture to a temporary zip file; -Loads it back as BranchGroup; -Extracts the geometries from it and creates an Object3D (a kind of solid); -Perform Boolean operations with two Object3D; -Perform the steps in reverse order until the new furniture is added to home. The XOR operations still don't work as expected. Even so, use it with care! ---------------------------------------- A computer program does what you tell it to do, not what you want it to do. Murphy's Law When all else fails, read the instructions. Murphy's Law If you don't like "AS IS", DIY. Dorin's law |
Current timezone is GMT Oct 20, 2026, 12:39:09 AM |
